| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | API 2A-WSD 21st Edition | ||
How is the plastic moment determined in calculation of the Chord Load Factor?
The plastic moment, Mp is calculated as the yield strength*plastic section modulus. The plastic section modulus is taken as 1.3 times the elastic section modulus.
