| Version: | V8, V8i | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
All dimensions are placed with a value of 0 - why is that?
Make sure to check the Scale Factor under Element>Dimension Styles>Units to ensure the Scale Factor is not set to 0. If set to 0, change the value to 1.0000.
