| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | API 2A-WSD 21st Edition | ||
Does the API implementation only check tubular joints?
Yes. The implementation only deals with the joints formed between the Circular Hollow Section Members. Any other type of joints are not considered by the implementation.
