| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | API 2A-WSD 21st Edition | ||
Can we specify a mixed joint classification?
Yes you can. You need to edit the filename.PUN file accordingly. If you have a joint which is 25% K, 25% X and 50%Y you need to specify 0.25, 0.25 and 0.5 in K, X and Y columns of the .PUN file for that brace chord combination.
