| Version(s): | 08.05.02.35 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Working in DWG mode and dimensioning.
If the user dimensions something in a DGN he has the option to put the leaders inside.
This doesn't seem to work too well in DWG mode. Having to had a really large dimension area. Shrinking the text doesn't help.
User will need to lower the min leader value to a smaller number.
It's suggested to save Dwg file to dgn and change the min leader value and then save it back to dwg.
