How to generate an animation of a cutout in a 3D model
  Product(s): MicroStation
  Version(s): 10.05.00.40
  Environment: N\A
  Area: Animation
  Subarea: General
The following will demonstrate how to animate a cutout in a 3D model
On occasions, it is useful to provide an animation to show what's inside part of a 3D model. For example, you may want to show the rooms owned in a large building, or see what is beneath a roads surface.
[Click here to download and view video]
  1. Open the 3D model
  2. Create a solid to be used for the cutout
  3. From Visualization workflow choose the Home tab, under Utilities group select Render Boolean Add tool.
How-to-create-an-opening-in-a-model-when-rendering
  Original Author: Carl Myhill
