| Version(s): | All | ||
| Area: | Steel Design Solutions | ||
| Subarea: | Verifications | ||
| Original Author: |
Bentley Technical Support Group | ||
The Verification Problem is referred to the example 6.8 of the WORKED EXAMPLES FOR STEEL STRUCTURES (AS 4100)
The axial compression capacity matches with that of the Staad Result as shown below.
The corresponding Staad model is attached herewith.
