| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | Verifications | ||
| Original Author: | Anisurya Ghosh, BSW-Structural Design, Bentley Kolkata | ||
The following is a validation problem for a detailed calculation of the Russian SP 16 I section design.
A 5 m long beam formed from a HD320X127 I section (Steel grade: S235), is checked for an applied UDL of -100 KN/m throughout the span.
STAAD PLANE
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
1 0 0 0; 2 5 0 0;
MEMBER INCIDENCES
1 1 2;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
END DEFINE MATERIAL
MEMBER PROPERTY EUROPEAN
1 TABLE ST HD320X127
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 PINNED
2 FIXED BUT FX MZ
LOAD 1 LOADTYPE None TITLE LOAD CASE 1
MEMBER LOAD
1 UNI GY -100
PERFORM ANALYSIS
PRINT FORCE ENVELOPE NSECTION 2 ALL
PARAMETER 1
CODE RUSSIAN
BEAM 1 ALL
*CMN 5 ALL
SGR 1 ALL
GAMC2 1.1 ALL
GAMC1 1.1 ALL
TB 1 ALL
DFF 200 ALL
*BMT 100 ALL
TRACK 2 ALL
CHECK CODE ALL
FINISH
Section Properties:
D= 320 mm, B= 300 mm, Tf= 20.5 mm, Tw= 11.5 mm, Ix= 30820 cm4, Iy= 9239 cm4,
Wx= 1926.5 cm3, Sx= 1070 cm3, J= 225.1 cm4, H= 2.069*10^12 mm6
Maximum Bending Moment = 312.5 KN-m
Material Properties:
S235
E = 206000 MPa, fy = 235 MPa, γc1 = 1.1, γc2 = 1.1
Check for Flexure:
We need to satisfy eqn. 41 of SNiP SP16.13330.2011:
M = 312.5, Wn,min = Wx = 1926.5 cm3, Ry = 235 MPa, γc2 = 1.1
Then, M/( Wn,min*Ry* γc) = 0.6275 < 1 (OK)
STAAD.Pro value is 0.628 [Matching]
Check for Shear:
We need to satisfy eqn. 42 of SNiP SP16.13330.2011:
Q = q.l/2 = 250 KN, S = 1070 cm3, I = 30820 cm4, Rs = 0.58*235 MPa, γc2 = 1.1, tw = 11.5 mm
Then, QS/(I*tw*Rs*γc) = 0.5034 < 1.0 (OK)
Check for Lateral Torsional Buckling:
Check for Combined Shear & Flexure:
We need to satisfy eqn. 44 of SNiP SP16.13330.2011
Check for Deflection:
(5*100*54)/(384*206000*1000*30820*10-8) = 0.0128 m
STAAD.Pro value is 0.0128 m [Matching]
Maximum member deflection = l/200 = 0.025 m
Ratio = 0.0128/0.025 = 0.512
STAAD.Pro value is 0.51 [Matching]
| Item | STAAD.Pro Value | Hand Calculated Value | % Deviation |
| Flexure Ratio | 0.628 | 0.6275 | 0.0796 |
| LTB Ratio | 0.63 | 0.6275 | 0.3968 |
| τxy | 0 | 0 | 0.0000 |
| Ratio for combined shear & Flexure | 0.546 | 0.546 | 0.0000 |
| λub | 0.865 | 0.865 | 0.0000 |
| λb | 0.5629 | 0.5629 | 0.0000 |
| Maximum Deflection | 0.0128 | 0.0128 | 0.0000 |
| Deflection Ratio | 0.51 | 0.512 | 0.3922 |
