| Version(s): | V8/V8i | ||
| Area: | Reference | ||
| Subarea: | Presentation |
How to propagate the Adjust Colors setting from Nested Reference Attachments to the Top Level Attachment.
By default, the configuration variable MS_NEST_COLORADJUSTMENT is not set.
Any color adjustment made to a top level reference is applied to all the nested attachments directly.
If the MS_NEST_COLORADJUSTMENT configuration variable is set to any value, then the color adjustments are applied cumulatively.
See Help topic "Working with Nested References" for more information.
Other Language Sources
