Design Property and Steel Design Boxes
 Product(s):STAAD.Pro
 Version(s):All
 Environment: N/A
 Area: Steel Design
 Subarea: General Steel Design Solutions
While I can look at the model with Stress Ratio values annotated next to the steel members that I have asked to be checked, when I do the member query (double clicking on the members) I don't see the Design Property and Steel Design boxes anymore. Why is that?
 Design Property and Steel Design tabs are not displayed for members which have not been designed. Are you sure you are clicking a member for which the design has been done? Sometimes, when ratios are annotated on the screen, the picture may become quite cluttered with data and in an effort to double click on a designed member, one may end up clicking on a member for which design has not been performed. So, first check that the member you are double-clicking has indeed been designed. If you are certain that STAAD has done the design and evidence of that exists in the analysis output file and in the postprocessing Unity Check tables, but still you are not able to see these tabs in the dialog box which comes up when you double click on the member, please send us your .std model and our support representatives will look into that.
