| Version(s): | 08.05.02.35 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
Info: Creating an %if statement to pick up a system variable defined at the OS.--setting up:
If Defined $(system variable) and Equal to .....
Else if....
What happens is the pcf file is reading and stopping at the if defined statement.
Has a user defined system variable set on some machines and not on others.
How to handle if the system variable does not exist
Here is an example of setting this up.
SYSTEM_Variable = $(SYS_Var)
%if $(SYSTEM_Variable) == "MICROSTATION"
Define list of variables here to be processed
%elif $(SYSTEM_Variable) == "POWERSURVEY"
%else
%endif
