| Version(s): | 08.11.09.459 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
I would like to be able to modify the menu structure of Microstation so that I can add a call to Internet Explorer to load a webpage, much like the SelectServices choice under Help.
Here is the syntax to start a url in a menu bar or icon
MDL LOAD WEBBROWS URL
