Seeing multiple sets of Design in the same STAAD file
 Product(s):STAAD.Pro
 Version(s):All
 Environment: N/A
 Area: Design
 Subarea: American Steel Design
I have multiple sets of design in the same STAAD file and I am only able to see the results for the final set in the Postprocessing mode (GUI). How can I view the results for all design sets in the GUI?
The postprocessing Layouts -> Utilization option can report the design results only for the final set of design. This is a limitation in STAAD.Pro as the program architecture does not allow that results of multiple design sets to be made available at the same time graphically. The analysis output file is the only place where you can view results for all design sets. The only way to view the results of a previous design cycle graphically is
  1. to go to the editor and comment out the subsequent design sets and rerun the analysis
  2. reverse the order for the design data blocks so that the set, for which the GUI data is needed, becomes the last set.
For the AISC 360-16 design code, one can now view the results of multiple design sets in the postprocessing mode as well . This feature is going to made available for other codes in future versions.
