| Version: | 08.11.09.459 | ||
| Area: | View | ||
| Subarea: | General |
Setting display order of master file and reference file graphics
In Microstation/J and V8 2004 the display order was mainly based on file order. In MicroStation XM this behavior could be kept by setting the configuration variable MS_LEGACYDRAWORDER. In MicroStation V8i this variable is no longer used.
This check box replaces a configuration variable that was used in earlier editions. Prior to the V8 XM Edition “legacy draw order” was always used, meaning that regardless of an element´s Z value, elements that were added to the file later were displayed on top. In the V8 XM editions, the element´s Z value was respected, but you could set a configuration variable to enable the old behavior. In the V8i and later editions, turning on this check box enables the old behavior.
How to order reference attachments
| Original Author: | Regie Wallace |
