| Version: | V8i | ||
| Area: | View | ||
| Subarea: | General |
You are having a hard time to keep overview about a lot of graphics in a drawing?
You just want to work on a part of your graphic? And get there quick?
A "Displayset" will work for you like a miracle.
Just take the elements you want to keep into the "Element Selection" - then go to the alternate context menu by Shift+Rightclick and select Displayset > Set.
There you go you only see what you need
To get back and see the rest of the graphics again go to "View Attributes" and switch of "Displayset" or again select Shift+Rightclick and then select
Here some video how to use it in 3D
How to use the element selection effectively to even enhance this workflow .... also when you work in 2D
http://www.youtube.com/watch?v=ka72CYMdLUA
To learn more also check out:
http://communities.bentley.com/Communities/Other_Communities/AskInga/w/AskInga/named-groups_2C00_-displaysets-and-quick-sets.aspx
