Here are the steps to add or modify strand location for Precast/Prestressed Beam sections:
- Open Precast/Prestressed Module
- Open the Beam Section library by clicking on Beam Section on the ribbon or by clicking on Libraries > Beam Section from menu:
- Locate the section and click on Modify
- Click on Template and make any additions/changes to height and # of Strands.
- In the Template dialog you can Add Rows, modify Height and # of strands individually or you can adjust all heights using the Adjust All button and click OK:
- Click on OK to on the Beam Section dialog to accept the changes:
- Finally click on Save to save the changes to the library:
