| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Steel Design | ||
| Subarea: | American Design codes | ||
What are the different AISC steel design codes supported by STAAD.Pro and what are the corresponding commands for these ?
The different AISC codes including commands to invoke each one, are presented below
AISC 360-05 :
Command : CODE AISC UNIFIED 2005
A design parameter called METHOD can be used to set the design type to ASD or LRFD for this code
AISC 360-10 :
Command : CODE AISC UNIFIED 2010
AISC 360-16 :
Command : CODE AISC UNIFIED 2016
Old ASD code :
ASD 9th edition ( green book ) : CODE AISC
Old LRFD codes :
LRFD 3rd edition : CODE LRFD
LRFD 2nd edition : CODE LRFD2
