| Version(s): | 08.09.04.51 | ||
| Area: | Visualization | ||
| Subarea: | Materials | ||
Bad version number for MDL application [Procedure map name]
Error occurs when trying to load a Procedure map (PMA) in the Material Editor.
One or more procedure map files (PMA) are invalid or bad.
Replace all files (including DLLs) from a known good installation.
