In RM Bridge Enterprise > Modeler, was defined the completely geometry for an Integral Steel Composite Bridge. In this video series, it is presented the structural analysis and design for this type of bridges.
The deck cross-section is defined with just one unique cross-section. It was used link elements for stiffeners, cross-beams and steel diaphragms over the abutments.
In Analyzer, Struct_check schedule variant, the User can obtain one first calculation with results for self-weight and eigen modes that can be displayed in Main View.
In Results > Load case list, User can now export total sum force results to a *.lst and/pr *.xls file.
