Error: -154 Reading Movie Sequence
  Product(s): MICROSTATION
  Version(s): 08.05.02.35
  Environment:  N\A
  Area:  Animation
  Subarea:  General
  Original Author: Bentley Global Technical Support
When loading frames into the movie player, message center reports:
Error: -154 Reading Movie Sequence.
Reason:
The movie player encountered a file with an invalid format. It could be file that is not readable by the movie player or a normally readable file that is corrupt or bad.
If the file is not a valid format, remove it from the folder containing the sequence files.
If the file is believed to be a valid format but does not load and is not displayable by other normal means (IE: image does not load in an image viewer), then the image will need to be re-obtained, in good working order, from the original source.
