Import DTM
In OpenBridge Modeler to import civil terrain data, users can go to the Home ribbon tab and select the Import / Terrain tool in the Bridge Setup ribbon group. Just select the file to import (.TIN; .DTM,..) and at the Import Terrain Model dialog settings specify the details of the terrain to import. In the Feature Definition group settings select one of the following options:
DTM
