| Version(s): | 08.11.05.17 | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
| Original Author: | Maike Mygent, Bentley Technical Support Group | ||
Clip Boundary inactive reference panel
The issue is, that the icon for the Clip Boundary tool in the reference
dialog box is grayed out when in DWG workmode.
Product: MicroStation V8i
Version: 08.11.05.17
Area: Reference
Workaround:
1. Place a fence where you wish to cut.
2. Right click on the drawing in the Reference dialog box
3. In the tool box press the Clip Boundary
Or update the version, the issue has been fixed in the newer version of
V8i Select Series 1.
https://communities.bentley.com/products/microstation/w/microstation__wiki/32464/not-possible-to-define-a-reference-clipping-boundary
