| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General | ||
| Subarea: | N/A | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
I have purchased a Structural Enterprise License; when I open a file in STAAD.Pro, I see the 'Bridge Deck' is greyed out. I thought with Structural Enterprise license, I should be able to run this module also called STAAD.beava.
To activate the 'Bridge Deck' tab, you must check the box for STAAD.beava under License Configuration. It should turn green.
Please note that this will also activate the 'Bridge Deck' module available under Mode.
