| Version(s): | 08.05.02.35 | ||
| Area: | Visualization | ||
| Subarea: | Render | ||
WARNING: Only n% of surfaces have been meshed!
Additional meshing may be required to display other views of this solution.
The file <(><<)>file name>.shp will be required for additional meshing.
Saved rendering database to <(><<)>path to design file>\<(><<)>name of file>.ptd
This message is appearing in Message Center when saving Particle Trace Solution to file.
Disable "Visible Surfaces Only".
This simply means that the current Particle Trace solution is not a complete rendering solution for the whole model.
This is caused by processing a solution while "Visible Surfaces Only" in the Particle Trace settings is enabled.
Steps to correct (if the need to render all surfaces is wanted):
1. Go to Settings > Rendering > Particle Trace
2. Go to the Meshing section.
3. Disable "Visible Surfaces Only".
4. Recalculate solution.
