In RAM Connection, the following types of vertical bracing connections can be modeled and designed:
In RAM Connection, axial forces can be assigned to the brace members as follows:
In RAM Connection, CBB joints can be created with the following configurations:
Connector |
Design Code | Column Section | Beam Section | Brace Section |
CBB: Column - Beam - Brace |
After connections are assigned to the CBB joint, the interfaces can be customized in the Connection Pad as follows:
Beam - to - Column Connection Options
Gusset - to - Column Connection Options
Gusset - to - Beam Connection Options
Gusset - to - Brace Connection Options Brace Sections: Channels, Rectangular, Angles, Circular, T-Shaped
Brace Sections: I-Shaped
In RAM Connection, CVR joints can be created with the following configurations:
Connector |
CVR: Chevron Brace |
After connections are assigned to the CVR joint, the interfaces can be customized in the Connection Pad as follows:
Connector |
VXB: Vertical X Brace |
After connections are assigned to the VXB joint, the interfaces can be customized in the Connection Pad as follows:
In RAM Connection, seismic provisions can be incorporated into the design of the following connection templates:
In the New Joint dialog, the seismic load resisting system and seismic design parameters can be specified vertical braced frame joints where seismic provisions are considered:
