| Version(s): | V8i, V8i (SELECTseries) | ||
| Area: | Visualization | ||
| Subarea: | Materials | ||
| Original Author: | Conor King, Bentley Technical Support Group | ||
Model / Solid will not display Transparent
Model or solid will not display transparent when using the Active Element Transparency Tool (can be turned on in Level Manager also) when a material is attached to a model/solid.
Change settings in Material Editor
Note: If Material Editor is in Advanced Mode, Transparency can still be applied from the Transparency tab beside Opacity field
