| Product(s): | RAM Connection | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | RAM Connection | ||
| Subarea: | Connection design | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
In RAM Connection when trying to generate the report, I am getting below error. Can you please help?
This issue is related to printer settings. Please change the default printer and try again.
