| Version(s): | 08.00.00.21 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
How to define RF_DIR using relative path(s) in V8
MicroStation V8 supports relative path names from user defined configuration variables. For example, you can define your own configuration variable, PROJECT_ROOTA, and have reference files defined as PROJECTROOTA:\electrical\xxx.dgn, PROJECTROOTA:\hvac\yyy.dgn etc.
This is much better than using the general purpose MS_RFDIR and if you move your file server, you just redefine PROJECTROOTA and all of the reference files will be resolved.
