| Version: | 08.11.07.443 | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
User has created custom task menus. They display in MicroStation Select Series 2 in one office, but not in another.
The following variable was found to be set to read only a select group of tasks in the .cfg files. . .MS_GUITASKTREEROOT = …..
Once the variable was deleted in their .cfg file, the task menus displayed.
| Original Author: | Derval Canny |
