Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
ANSWER:
Moments amplified by P-Δ are used only for column design ,they are not applied to the cap but in V15.00.00.41 user can include the P-Delta effect for footing design.
So only moments amplified due to Moment magnification method will be transferred to cap and footing.
