| Product: | RAM Elements; RAM Connection | ||
| Version: | All | ||
| Area: | Export |
A Column Beam Brace is rotated once sent into RAM Connection:
It looks upside down because RAM Connection uses the column local axis to locate the braces and the columns in RAM Connection:
You can invert the direction of a member (change the NJ node for the NK node) with next tool:
