| Version(s): | 08.11.09.292 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
| Original Author: | Daniel Koval, Bentley Technical Support Group | ||
Is there a seed file for PCFs?
User would like to know if there is a seed file or a template file for Project Configuration Files. ( PCFs )
Is there a way to add specific configuration variables to a Project when a New Project is created?
There is a Project.Template file in the Projects folder in the Workspace.
Default location on a Windows 7 64 bit machine is:
C:\ProgramData\Bentley\MicroStation V8i(SELECTseries)\WorkSpace\Projects\
Anything that is added to the Project.Template file will be placed in all newly created .pcf files
