Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support GroupĀ - VM
ANSWER:
Tutor 3 example file has information on how to input the Strut and Tie model to Pier cap and footing .
Also the user can check the tutorials which explains the procedure on how to model the Struts in footing.
