| Version(s): | 08.05.01.25 | ||
| Area: | Configuration | ||
| Subarea: | General | ||
Key-in that contains a configuration variable and a Path that has spaces in the folder name.
Issue: Run a keyin with a configuration variable in the string. If the variables path contains any spaces, quotes will need to be added outside the variable being used.
Quotes will need to be added outside the variable being used
Example:
Key-in: expand keyin reference attach "$(_dgnfile)" Default,,,,
