| Product(s): | RAM Connection | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | RAM Connection | ||
| Subarea: | Connection design | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
In RAM Connection for a CBB connection how Lev,bottom and Lev, top are calculated?
Lev,top and Lev,bot are the top and bottom end distances of the portion of longitudinal weld over the gusset-to-end plate interface. They are calculated using the connection data in the pad and the gusset geometry, like this:
