| Version(s): | 08.09.04.xx (XM Version) | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
| Original Author: | Maria Munoz, Bentley Technical Support Group | ||
Configuration variable MS_DWGSAVEAPPLICATIONDATA= 1 does not seem to work for MicroStation V8 XM Edition.
This is related with another configuration variable MS_DWG_LEVELDISP_FOR_VPORTFREEZE.
In MicroStation V8 XM Edition you can workaround it by setting MS_DWG_LEVELDISP_FOR_VPORTFREEZE=OFF, only IF the user does not need the setting for MS_DWG_LEVELDISP_FOR_VPORTFREEZE.
Otherwise, it is suggested to upgrade to a newer version of MicroStation where this bug has been fixed.
