Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Answer :
Yes, while designing footing the program checks for Minimum Reinforcement Criteria as per AASHTO LRFD 5.10.8-1
LRFD 5.10.8 requires to check temperature and shrinkage steel in footing as per equation 5.10.8-1.
