Applies To | |||
Product(s): | RAM Connection | ||
Version(s): | Connect Edition | ||
Environment: | |||
Area: | RAM Connection | ||
Subarea: | Connection design | ||
Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
Can directly welded round pipe truss connections be designed in RAM Connection without the use of gusset plates?
I think you are using AISC code for this case. If that is true you can use Chord Branches template available for AISC code which will allow direct welding between hollow sections. Please see the attached snap for clarity.
