| Version: | 08.11.09.459 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
UCF files will be saved on the network automatically when defined via configuration variable_USTN_USER in the cfg-file (e.g.Home.cfg).
Definition of the variable is the path to the folder where ucf files will be saved as shown in the following examples:
_USTN_USER = M:/MicrostationV8i/WorkSpace/Users/
_USTN_USER = M:\MicrostationV8i\WorkSpace\Users\\
Note: The ucf-file which was last time in use in MicroStation has to be manually copied over to the server. The ucf-file which will be generated in MicroStation afterwards will be saved in the defined location automatically.
Error message when starting MicroStation, "ucf not found"
| Original Author: | Andrea Figurova |
