Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
ANSWER:
When the slab is poured there is no continuity only the load is applied to the deck is treated as continuous model and since the slab concrete is fresh concrete, at this time the DL reactions are calculated and the slab is treated as simple span. This is the reason the program shows same reaction for both simple span as well as continuous span bridges.
