| Product(s): | RAM Connection | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | RAM Connection | ||
| Subarea: | Connection design | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
In RAM Connection where can I get the manual?
In RAM Connection you can go to File > Help and find the RAM Connection manual pdf.
This is kept in the system in below location if RAM Connection is installed.
C:\Program Files\Bentley\Engineering\RAM Connection\Documentation\en
