| Version: | V8i, CONNECT | ||
| Area: | DGN | ||
| Subarea: | Save |
How to enable 3D?
There is no enable button.
To create a 3D DGN file you should:
- open a 3D file
- or create a 3D file by using a 3D seed file,
- or you can export your 2D file to 3D by going to File > Export > 3D
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/3d-microstation
| Original Author: | Elisa Pry, Bentley Technical Support Group |
