| Version: | 08.11.09.292 | ||
| Area: | Configuration | ||
| Subarea: | General |
How can I make MicroStation wait for predetermined amount of time then resume normal operation?
MicroStation does not currently provide keyins to cause a predetermined delay. MicroStation does provide you the "expand keyin" keyins that could start external programs and remain frozen/hung until that process completes. You could create your own DOS batch file or Windows script to sit and wait for a period of time then when complete MicroStation will resume normal operation. here is one way to force MicroStation wait 5 seconds:
1. Create file c:\wait.bat consisting of these lines:
@echo off
set /a WAIT=%1*1000
echo Waiting for %WAIT% seconds..
ping -w %WAIT% localhost > nul
exit
2. Start MicroStation and execute the keyin:
!c:\wait.bat 5
Where "5" is the number of seconds to wait.
3. The keyin can not be inserted into a batch file at a designated point to pause the batch process.
