| Product(s): | RAM Connection, RAM Elements | ||
| Version(s): | Connect Editions 13.06, 16.05 | ||
| Environment: | Windows 10, Dell PC | ||
| Area: | General; Graphics; User Interface |
It has been observed that on few machines using RAM Connection, while hovering the mouse on icons in the side panel, they look distorted.
Investigation on this has identified the cause to be related to DELL machines which runs AWCC Service that is AlienWare Command Center.
Similar issues may occur with RAM Elements; adding the executable (RAMElements.exe) in the exclusion list as above will correct the problem.
P.S. The folder ProgramData from step 2 above, may be not visible to you; you should check with your IT group on that.
Notes:
Any updates to the ‘AlienWare Command Center’ or AWCC service can cause the BlackApps.dat file to get reset to default, in which case, the graphics problems would resurface. In such cases, one would have to repeat the steps 1 to 6 listed above.
Distorted graphics in STAAD.Pro on Dell Alienware computers
Structural Product TechNotes And FAQs
