| Version(s): | 20.14.06.23 | ||
| Area: | Analytical Modeling | ||
| Subarea: | Import/Export Solutions | ||
| Original Author: | Steve Crabtree Product Advantage Group | ||
When trying to import an ISM repository into STAAD.Pro you get the following error:
No STAAD filename is provided. Unable to connect to 'STAAD.Pro' instance. Check if STAAD.Pro application is running.
This error is caused by an older non-ISM compatible version of STAAD.Pro. Upgrade the the latest version to resolve the issue.
