| Version(s): | 08.05.02.27 | ||
| Area: | DGN | ||
| Subarea: | General | ||
When trying to save a file to V7 format an error is generated. "Error creating file".
File saved fine on another PC.
It was narrowed down that the other machine was loading different resource files and one seemed to be corrupted. Once removed the save as process completed.
