| Version: | All | ||
| Area: | DWG | ||
| Subarea: | General |
Will MicroStation support the .dwf format?
Creation of .DWF format files through MicroStation will not be implemented.
The DWF format is a proprietary (non open) format owned strictly by AutoDesk.
