| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Geometry | ||
When I apply Solid Pressure Loads I am required to choose a Face Number.
How to I determine the face number for the solids in my model so that the load can be applied on the correct face ?
You may right click within the Graphics Window, choose Labels and use the option shown below to highlight the different faces for the solid elements
