| Version: | 08.11.07.171 | ||
| Area: | DWG | ||
| Subarea: | Open |
Error "dbobji.cpp@6858" when opening a DWG file.
When opening specific DWG format files this error message appears:
RealDWG Error !!dbobji.cpp@6858: eNotOpenForWrite
in version V8i (SELECTseries 1) 08.11.07.171.
In other versions (e.g.) V8.5 the file cannot be edited.
An issue was found in the RealDWG Library which has now been fixed in 2011.
Workaround:
| Original Author: | Jutta Eisenhauer |
