| Version: | V8, 2004, XM, V8i | ||
| Area: | File Access | ||
| Subarea: | N\A |
Running Verifydgn from a Command Prompt
To run VerifyDgn through the Command line or Dos Prompt:
First you will need to change directory to:
..Bentley/Prgram/mdlsys/asneeded
Here are the two command line switches:
In order to verify that the file can be worked on:
USTATION -VERIFY FILENAME.DGN
In order to repair the file:
USTATION -VRG FILENAME.DGN
The first of these commands does a read-only verify on the file, and lists any defects it finds in the console window.
The second command does a "Verify and repair graphics" in which a few of the known types of defects can be corrected, listing
verification and repair progress in the console window.
Recovering Corrupt DGN and DWG Files
